sikeston34m
sikeston34m's Avatar
Smile 10.26.2007, 09:05 PM
On the Cyclon website specs for the Car 2000 are:
"Power with 16 cells : 600 W continous , 900 W peak (30 seconds)
Efficiency : 89% at 16v - 31amps, Timing 4 degrees
Current: 35 A continous, 60 A peak (30 seconds)
Kv = 2093 Io = 1.7A (6v)
Dimensions : Diameter 36 mm, Length, 53mm (without shaft), weight 160g"
I figure I'm right at the rating for the ESC, but I'm slipping by with the added cooling of the fan.
I took a closer look at the winding and the magnets in this motor. It is a 12 pole stator wound like a 6 pole! Inside the endbell the magnets are extra wide. It is being operated as a 6 pole. Interesting. I would love to play with different windings and be able to record the rpm's, amp draw, etc. with 12 pole outrunners. (whisper whisper--------Direct drive E Revo)
