Should I try this? HV setup Questions
Should I try this? HV setup Questions - 10.26.2007, 10:46 PM
I just received a kontronik Jazz 40-10-32
Wanted to try it out in my hyper7 on 7s lipo with an aveox 36/24/3 motor.
Motor is 1300 kv
Batteries are 4000mah maxamps, a 3s and a 4s pack
Controller is good to 10s lipo
Not sure if 40 amps will be enough on power handling by the esc. Motor is rated as 26/40amps on the box, and is similar in size to a feigao L can motor.
I am sure the batteries can keep up, they work fine in my 10th scale setups.
Any info or ideas a re welcome, i know some of you guys have run kontronic and aveox before so let me know what you think.
