lutach
lutach's Avatar
10.27.2007, 11:45 PM
So, you are seeing what I saw then, as far as a voltage spike to the battery? I saw, IIRC, about 0.25 - 0.5 volts spike, so even a little potential over the battery packs voltage will result in decent current levels going into the pack.
I will have to agree. The spikes seems like 0.25-0.5. I also noticed a sound coming from the ESC (Schulze 18.97). I listened closely to figure out where it was coming from and it was from the capacitors. It sounded almost like when you take a picture and the capacitor inside the camera recharges after the flash, but it was more like a blow-off valve. I have to see if the same spikes appers with the MM. If so, I think setting a little drag brake might throw some charge back into the pack.
