which would draw more amps?
A4DTM
which would draw more amps? - 10.29.2007, 04:21 AM
feigao 540c-9L (3345kv)
neu 1515 2.5d (1700kv)
in a 1/10 4wd stadium truck, on 5s1p lipo, both geared for the same speed (~75mph)?
the neu says 700-3000watts, so on 20v, that's 35-150amps.. should i expect peaks as high as 150 amps?
the feigao is 88amps (the 540-7L is 3500kv, which is similar to mine). the feigao would also be around 67k rpm. while the neu would only be 34000rpm.
i guess what im looking for is which would draw the least ammount of amps?
