crazyjr
crazyjr's Avatar
10.31.2007, 07:44 PM
I'm sure the 8012 would work with the right motor, but the Novak will pull too many amps while running. Most consider the Novak as a starter system and something to move up from. Even if the setup works the motor would probably overheat anyways. the Novak provides more juice and i believe that helps with cool running.
