11.02.2007, 01:23 PM
Be sure to leave the motor brace in back loose whenver you move the motor. Its should slide back and forth until you have the mesh set, tighten the motor screws down, then tighten the brace screws.
If you don't the motor can be a bit offset even when you think you've put the mesh back to the same place.
