lipomax
02.17.2005, 10:26 PM
Actually, I can tell you that the 2700 geared 18/66 with stock tires and 22.2 volts 3100 polyquest gets to about 33 mph in first gear. In first gear, the amp spike is at about 65 amps and voltage drop is about 18 volts - that's for a REAL short time though. In second gear, the voltage spike goes to 15 volts and amp spikes to 90 amps. I would say that any 6s brushless lipo setup with gearing set for low to mid 30's will only draw about 70 amps peak - so getting a slower motor geared taller, or faster motor geared shorter will all yield about 60-80 amp peaks. The Kokam can do 60 amps continuous so I believe with the Kokams, you'll be well under the limits of that battery pack. I'll post a graph soon - the first 4 big peaks are in first gear and the second two big peaks are at second gear.
