Thread: MM Timing
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
11.04.2007, 05:49 PM
DM...it's impossible for a manufacturer to tell you that. You would have to test it in your vehicle with your gearing and your battery packs. Turning timing up you will get more power off the line, but your top speed will be lower as the voltage will be lower under load. Turning timing down the top speed is achievable, but off the line performance "suffers"...we already have too much power than we can handle...I run lowest timing on all my vehicles.
Joe Ford
Product Specialist
