Originally Posted by neweuser
Odd....what batts are you running? 52 associated on a strobe???
I have not installed the Strobe yet. MetalMan is correct the 52t is used with stock slipper plates, Associated slipper balls and a heavy duty spring(sprong?) I wasn't sure if that would hold so I got a Strobe with the 51t and a 20t pinion(the 19t were out of stock).
I use two 2s1p TrakPower LiPo batts.
