Jeremy1976
11.07.2007, 07:02 PM
Originally Posted by Matthew_Armeni View Post
The highest you can gear with the Tekno setup is 18/34 (for sure) possibly 19/34. If you install the wide ratio gear set you're still only looking at about 40 top speed. Either go up in cells as Brian suggested or get a hotter motor, 8XL or 7XL, if you want to go cheap, or if you want something better, a neu 1515 1Y geared 18/36 with the wide ratio should give you 45mph, if the winds behind you. That's fast though, I can try to get a vid up of my Revo, look at my sig for setup info, it's basically what you are talking about running. I'm pretty happy with it, but I still have the standard ratio, plan on getting the wide ratio soon. I'll try to get the vid up by Fri, if you haven't bought anything yet I'd suggest the neu motor, a 4S pack, and a MM. So your only real expense will be the motor.
Thanks for the info. I think I will go with the Neu that you mentioned and a 4s. I think I will hold out for the MMM though. Any idea when it is to be released?
