11.10.2007, 04:01 PM
Good luck sike, I had good success with my POS redcat that I had the outrunner in, I chose the motor so that I could use the stock drive cups from the original trans, not much thought was given to kv, thus the need for tiny tires, LOL.
What esc will you be using? Quark for the timebeing, or something that can handle 8s lipo? Startup adjustability is the key with these outrunners. The quark on its highest settings work well, but it would have been nice to have and adjustable throttle curve like the MM. I found that very small throttle inputs caused cogging, but a little more throttle at startup solved that and it would roll very smoothly after that. Ramping up the throttle curve for the first few increments would ave solved that issue. Maybe I was using too small of a motor and too high kv. A 650kv would have worked better than the 833 and maybe a larger diameter would have helped startup.
Good luck and keep posting, I have another revo that may get something like this!!!!
