DrKnow65
DrKnow65's Avatar
11.12.2007, 08:57 PM
jordan, poke around a but on the forum, use the search engine to ask basic questions, and if you don't find what you're looking for post the q's.
Brushless motors are rated in ####KV, i.e. 2400KV (means this motor turns 2400 rpm per volt of power) also motors are rated in watts handeling (i.e. 1100 watt motor will not get as hot at 1000 watts load as a 800 watt handling motor). Lots of math involved, so you propably would want to find successful combinations to copy until you get an understanding for it all.
There are also "sensored" and "sensorless" brushless motors which is why the novak/feigao don't work togeather... again poke around for awnsers.
