11.13.2007, 03:12 PM
Ok, thanks Serum! Dimensions don't really matter. Simply a diff mount for a HB diff using a Kyosho spur, with pinions ranging from 9 to 24 (all available mod1) with the standard motor holes and all. The bearing support through hole is 13mm and the other is 16.2 I believe. I figured 1.4mm on both sides was enough, but not to much. The BPP mounts hole is pretty small, but thats a Ofna diff.
