11.14.2007, 03:56 PM
You have to do the inital setup so that the controller will know the high, low and neutral of your radio system. If you are using a futaba radio, set the throttle channel to reverse, as the quark will not program with it set to normal. Also zero all trims and set the endpoints (if you have that setting) to the max. You do not need to adjust the std and adv menus to get it running, but you may want to depending on startup and battery preferences.
