sikeston34m
sikeston34m's Avatar
11.16.2007, 02:35 PM
WOW! So does it run smooth and quiet besides the minor cogging? I agree that turning it to 'outrunner' will probably treat the cogging issue. I hope you get the programming figured out..
Move throttle to 'min' position...
Turn 'on' esc switch...
Press and hold the esc program button and move the throttle to 'max' and hold..
Release the program button after 2-3 seconds...
Now move the throttle until you hear recognition beep...
You should have entered advanced programming mode... the LED pattern should be the two inside LED's (green and yellow), move the throttle to change, yada yada yada.
It runs VERY smooth and VERY quiet. The tire noise is louder than the motor unless I slip off into the grass.
It needs programming and More voltage. I'm gonna be working on those two things next.
Are these good caps? Do you know where to find the spec sheets? I tried the HO number on the nichicon website with no luck.
