sikeston34m
sikeston34m's Avatar
11.16.2007, 07:43 PM
Does the setup have enough torque to wheelies at speed? What Kv. is your motor?
So you are talking stator dimensions, not the outside dimensions, correct?
One of those Scorpions looks larger than the Axi, 40mm stator, 25mm length.
I don't know what rpm the motor is hitting, but I know an outrunner should be hitting 6500-7000rpm to get 45mph in a Revo with moderate ballooning tires.
No it will not wheelie. The AXI 4130/20 is 305kv. It's the largest motor that produces the most torque that will fit the space and the stock transmission output shaft.
Yes I'm talking stator dimensions.
On 6S A123, I figure I'm hitting about 5500 rpms.
