Well, I went ahead and drew up some wide CRT .5 A-Arms. These are renderings of the front arms. I'm still working on the rear ones. If machined out of 6061, predictions are 34g. I'm sure a lot more material could be removed without sacrificing weight, but in the current form, I think these are going to be EXTREMELY durable.
For the rears I was planing to incorporate a 5-10mm extension (frog leg) into it, much like the Revo setback arms. I was also thinking of incorporating a way to adjust the amount of extension (though the adjustment range would have to be small or else the dogbone would bind or fall out at the max settings in each respective direction). However, the biggest downside is that it would mean that two separate CVD lengths would have to be made (one for front, one for rear), and for this reason I am going to ditch the idea and not have any set-back.
