Serum
Serum's Avatar
11.18.2007, 04:04 PM
that's somewhat of a problem Jasper; IIRC that diff uses 5mm thick shafts on the cups instead of the usual 6mm shafts.
You need a hotbodies C8019 cup and a set of hotbodies internals. (or kyosho should be fine too) (bevelgears/crosspins etc)
To make it even more fun; you can't use this ofna diffbulks with the other diffs, since it uses a complete different size of bearing..
