sikeston34m
sikeston34m's Avatar
11.19.2007, 08:43 AM
Originally Posted by johnrobholmes View Post
Patrick del Castillo told me it was 10% of the kv. With a rollout of 6.5 inches that would put this rig at a min speed of .3 mph or so, but I would at least double that figure or more to be conservative. The startup speed of the ESC is not the same as the minimum sensing speed however, so it might be trying to start the motor up much faster. Once you put the new diffs in your startup issues should go away, especially when you volt up.
Volting up right now might even help the startup, if only making it more abrupt and violent.
I really dig the build, I love how low and clean it looks. I still want to try this, but I sold my revo a while back and the emaxx isn't getting parted out yet. I have a 3032 I want to try, should be about like a 4020
Aaaaaaaah, so there's some confirmation about what's going on here! I'm VERY sure that with lower gearing, this thing is going to be a BEAST!
The reason why I want to switch to the 4120/14 is the higher kv to work with the Quark. It will have more than enough torque to work with the lower gearing.
I'm wondering something about the new 4120 motor. It's 15mm shorter than the 4130. Is there enough room to put the mechanical brake back in there and go with a HV forward only ESC? An ESC like the Phoenix HV 110amp version might be a good choice then. The Voltage could be cranked up as high as motor temps would allow. I think that would be pretty high, since this setup gets rid of the heat well. Is there such a bracket for the brakes though? Before it was mounted on the transmission, which is obsolete with this setup.
Thanks for your compliments. The low center of gravity that this has, REALLY sticks it to the ground. It's gonna high speed corner VERY well. I know on gravel, I could turn the wheel sharp at 30+ mph and it would just go round and round like it was on ice, instead of tripping/flipping over it's front tires. LOL
I don't think I like the Revo tires very well. Will prolly be changing out to something else. The E maxx's gator tires grip really well for off road.
John, I'm sure you are looking at the Scorpion 3032, correct? I put a 3032/10 in a Direct drive to transmission setup in an E maxx. It was a great performer for the first pack.
You gotta think about how much we are pushing, jerking, and tugging on that stator with this type setup. I ripped the stator from the bearing holder. In other words, the stator spun loose and ripped the windings from the power leads.
At the factory, sometimes I think they don't loctite the stator on both ends. This appeared to be the case. Even on the AXI 4130 that is in this one. Same thing. A prop doesn't have brakes like we use constantly or the resistence of acceleration that we are asking.
I used Red Loctite between the stator and the bearing holder on the endbell side. I had to slow "bake" it at 100 degrees for about 6 hours to get it to set. Green Loctite is the Better choice. It weeps into the microscopic holes and sets quicker with no temperature increase. I would make a puddle there and it would soak in, then I would do it again. About 3 "puddles" soaked into that crack, so I think the void was completely filled.
I know you plan a custom wind, I just don't want you to learn the hard way like I did. Let me know how it works out.
