11.19.2007, 02:49 PM
Of course, the battery you use to power the charger will have to have more Ah capacity than whatever battery you are charging, depending on the pack voltage too.
You can use a cheap modded PC power supply if AC is available, or use your car battery as long as you're not charging packs all day.
