DrKnow65
DrKnow65's Avatar
11.21.2007, 11:21 AM
From what I can gather (since no one has a MMM yet) it uses lower resistance higher voltage Fet's (the switches) so it should run cooler and therfore more efficiently... Either way it's built for 6S instead of 3S so if you have a problem with it while on 6S it will be "within specs" and therefore under warranty. I just want to know if it will run on 8S ;)
(and it comes with a "neu" style motor)
