rchippie
rchippie's Avatar
11.25.2007, 10:54 PM
Originally Posted by ssspconcepts View Post
Thanks Hippie...maybe Brian or one of the other seasoned vets will pick up the question and run with it.
I hope you got your wheel situation squared away (or should I say rounded away)....
Yes id did get it figured out. Who ever said i needed the FR wheels was right. So im going to get either traxxs rims or rpm rims. I also thought about using the B3 wheels that come with the kit. But if i do that the tire width when mounted will be a 1/4 inch narrower. I have to buy new foams because the acetone i used to soak the tires of the wrong rims split one of the foams. so im going to buy firmer foams because to stock foams were extremely soft.
REAL MEN RUN BRUSHLESS
