crazynic
11.27.2007, 03:27 AM
Originally Posted by skillx View Post
I am using the Bigmaxximum with a MM and 5s. It works perfectly with 16/52 gearing and stock diffs. However, Mike has told me that for some reason all the new MM that are being sold cannot handle 5S or that they simply won't run on anything higher than 4S. Sooooo, with 14 nimh cells I would think you should be safe but i don't really have a clue because I have only ever run lipos. I don't own anything else.
A lot of users have reported that the MM wont handle 14 cells either ....it just wont arm at start up....its internal voltage limit is like 20 volts or something......a freshly charged set of NiMh can be over 21 volts...
So its 4s or twelve cells to stay safe.
