Matthew_Armeni
Matthew_Armeni's Avatar
11.27.2007, 09:52 PM
Originally Posted by dirt101 View Post
dont you think that gearing is a little tall? what temp do you get and how much does your truck weigh.
if I were you I would definatly wait until you have enough money to get a feigao. going from a standard to an xl motor, the power difference is amazing, and you will beable to gear higher. IDK about 19/36 high but definatly higher than 9/40. If you must go with the 4600 for a while you could try it on 4s if you have a 4s battery.. I hear a lot of ST guys running there 4600s on 4s and I havent seen any problems.
19/36 isn't that tall because the 9XL spins so slow, even on 4S. It has the torque to move the truck quickly without a problem (with a 2-speed) and get good top speed as well. Without a 2 speed though, you may want to gear lower to have a better range. I'm running 18/36 with a 9XL ad my motor temp has never gone above 160's and the ESC and battery are under 120.
  Send a message via AIM to Matthew_Armeni
