11.28.2007, 12:01 AM
You have the hb cup correct? It is 8mm, as is the pinion shaft (makes sense as they are designed to fit together). The ths cvds have a larger ball than a std revo/maxx cvd. You could drill the included ths cup out to 8mm and us it in place of the hb cup. Not sure if there is enough material left for the set screw to hold though. Nothing like a little "interface" issues to really get you aggrevated, huh?!
