Originally Posted by MetalMan
This truck has caused me to stop procrastinating on turning my MT2 into a direct-drive outrunner-powered truck. Now I have everything I need, except for the custom shaft that still needs to be made.
Thanks a lot
The MT2 looks like a pretty awesome truck. Are there aftermarket 1/8th diffs available for it also? I'm gonna check that one out a little more. Only weighs 5 pounds! I like that!
In considering other trucks for direct drive conversion, just remember what we've ran into on the cogging issue. I think that line that you can't cross is somewhere about 4 inches of roll out per turn of the motor. Vehicle weight affects this I'm sure.
But more so, I believe it also has to do mainly with the level of EMF pulses that the ESC MUST get from the motor to start properly. More on this later.
