MetalMan
MetalMan's Avatar
11.29.2007, 07:37 PM
The MT2 looks like a pretty awesome truck. Are there aftermarket 1/8th diffs available for it also? I'm gonna check that one out a little more. Only weighs 5 pounds! I like that!
In considering other trucks for direct drive conversion, just remember what we've ran into on the cogging issue. I think that line that you can't cross is somewhere about 4 inches of roll out per turn of the motor. Vehicle weight affects this I'm sure.
But more so, I believe it also has to do mainly with the level of EMF pulses that the ESC MUST get from the motor to start properly. More on this later.
The MT2 is pure 1/10 scale, no optional 1/8 diffs. The diffs are actually a weak point on it, even with the optional hardened diffs on the 18SS kit (which are the ones I started with). However, aluminum diff housings have fixed that issue for me, in combination with the hardened diff gears.
My motor is a KMS 4120/06:
http://www.hobbypeople.net/gallery/108521.asp
I get these at a discount 'cuz I work there. It uses a 6mm shaft, so I have a 6mm steel rod that I will turn down to 5mm where the dogbone cups attach.
Only problem that I have found with the MT2 so far, is that the stock chassis is pretty narrow.
