Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
11.29.2007, 09:55 PM
Originally Posted by sapper_triple6 View Post
OK couldnt get the heat to work. Looks like I will be drilling the screws out and sacrificing the mount.
WAIT!!!! There is another tool you can use. They are specific drill bits for removing stripped out screws. Here's an ebay auction with the info:
http://cgi.ebay.com/Alden-ProGrabit-...QQcmdZViewItem
Its a double sided tool that fits in a drill. The first side drills out the top of the screw. Then you flip it over and reverse your drill. The second side looks like a tap. It fits exactly into the hole side 1 drilled. Side 2 sinks into the drilled out hole and removes the screw. I use mine a lot on my RC's when the hex head screws strip out. I bought mine at Sears were Craftsman sells them. You might be able to save your mount.
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
