sikeston34m
sikeston34m's Avatar
12.01.2007, 01:46 AM
Thanks for the recomendation. I can always cut and weld my center dog bones to the correct length if needed. A longer stator would be the best bet for this setup as it needs some more torque. Does axi make a similar sized motor to the scorpion 30xx motors? Which scorpion/axi would I want to use? Thanks a bunch for the advise, I have plenty of inrunner experience, but not a wholelot of outrunner testing under my belt!
What does the Redcat weigh?
This motor looks pretty good for the specs you gave.
http://modelmotors.cz/index.php?page...e=12&line=GOLD
That is AXI's website. They make alot of different size motors.
PS. A little off topic, but was there a special bearing that you used on the 1/8th diff pinions? I know you were having trouble getting them to hold up
