12.02.2007, 11:05 AM
Robert, I know what you mean, I've read up on the bead problem, Imex makes a 2.8"-12mm rim that has a standard bead. Still the tire choises are limited. I was hoping that using the anaconda or one of the imex tires on a lighter buggy would help to curve wear? That and being consious of not breaking traction...Or going with plan A to run 1/8th tires.
Serum, having this setup come loose has been a problem for some of the guys racing the SB V2 Pro with just the standard 1/10 tires... Loctite has been the fix but I'm up for any other ideas of how to pull this off.
