sikeston34m
sikeston34m's Avatar
12.02.2007, 11:30 PM
Originally Posted by MetalMan View Post
Here's the stator:
I was modifying the motor shaft, and got both ends turned down to 5mm, and the groove for the snap ring cut, using a combination of my drill press, Dremel with reinforced cutoff wheel, and file. However, I wasn't able to drill the holes the pins will go through. One hole is now about 1mm deep, but then my drill bit broke... This steel is very tough. Time to order a new drill but, and hope for better luck next time.
Better order more than just one drill bit if you plan on drilling that. Get Cobalt! That's some really hard stuff!
The AXI I used on the Revo had the snap ring too. I didn't use it. The magnetic force keeps everything in line as long as you don't have a prop out there pulling on the endbell.
That looks like one tough stator. You don't have to worry about that one spinning on the bearing holder being key like that. Thanks for the picture.
