glassdoctor
TEAM FUSION
glassdoctor's Avatar
12.06.2007, 12:12 AM
Being in the UK might make the choice of motor/esc different. You might have different options that are more cost effective... what is cheap to us might be for you. For example, you might be able to run Mtroniks stuff cheap?
In general it won't be hard to get a nice conversion to run 25 minutes. Especially if you run a high-end motor. Lehner, Plettenberg, Neu...
A good lipo with at least 5000 mah will be enough if you don't go crazy on the motor choice. 40mph is pretty fast, so you might need 6000mah+
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
