MetalMan
MetalMan's Avatar
12.07.2007, 03:04 AM
Originally Posted by ren View Post
What about making wheel hub extenders like they do for 1/8 buggies and trucks?
http://www.amainhobbies.com/product_...ducts_id/12748
It seems this would be an easy fix and would eliminate needing longer driveshafts and arms, but I don't know how easy it would be to machine.
That is a valid idea, although it's not always so practical - by pushing the wheel out further, it effectively allows the force from the wheel to have more leverage against the bearings. This causes premature bearing wear, and then extra replacement bearings. But by keeping the wheel in the same spot relative to the bearings and a wider arm, the result is a wider truck without any abnormal bearing wear.
