crazynic
12.07.2007, 07:09 PM
Originally Posted by Patrick View Post
It's looking pretty good.
Personally I wouldn't feel comfortable with my servo wire looped around the drive shaft, but it might be ok. When you put the esc to rx extension in, just be careful it can't end up in the spur gear.
What batteries are you going to use?
Don't worry i have not been driving it like that
I just mocked up the receiver and battery tray locations for the pic...
I think i will open up the servo and re-solder the wires shorter....
I'm not happy with the wiring around the ESC/fans but its hard to get it neat with so much wire
I will be trying both 4s and 5s to work out what works best for me....
I have been trying to get some batt's from True RC but Dan must be busy and i have not been able to place an order....
I have also got a max amps 6000mah 5s2p pack on the way so i can get this baby running.....
