Finnster
KillaHurtz
Finnster's Avatar
12.08.2007, 06:28 PM
Originally Posted by ncalenda View Post
neat, now I wanted to try a diff motor, but how do you find gears to fit a 5MM shaft for 48P?
Its actually a 1/8 shaft on th 1920. Good, as I was thinking I was going to have to convert to 32p, and get a 32p 5mm pinion w/ bore reducer to 4mm. May go to a 32p setup later and run jato spurs, maybe, or save for the CRT .5.
The Rustler is meant to go only so fast, VXL labeled or no.
A 5mm shaft is about bigger than a 48p pinion lol
