Thread: NEW Pics!
12.10.2007, 01:44 AM
Ah, the align 600xl. They work well, I had one setup in an emaxx. No problems moving it around on 5s. I still have an align 600l that will go in a buggy or something. You will not have any clearance issue with the flm tranny. I have an flm pede with a plett maxximun in it, running jato spurs and 32 p pinions. Not sure on the size, but I know that a 46t mgt spur is the largest that will fit on a rustler tranny before it hits the driveshaft output on the gear side. You will have to use a large pinion to get the gears to mesh with that align, it is 43mm in diameter!
