GO-RIDE.com
12.11.2007, 06:23 PM
Correct ME, if I am wrong. But your runtime will go DOWN when running 3s over 2s setup... higher voltage will allow more current, and thus exponentially more power (volts x amps= watts). This is according to how anyone would drive a BL truck (handfuls of throttle)... however, if you hold a constant speed (say, to hold same speed for both 3s and 2s), or drive it the same as 2s, the 3s setup will have a longer runtime.
That was my theory, but the only indication I have is that the packs I quoted are nearly the same size and weight. I'm guessing they have the same # of lipo cells, they are just wired differently. One is a 3100 3s and the other is a 4200 2s.
E-8ight - Tekin RX8 2000kv/4S
