Mod Man
12.16.2007, 08:35 AM
You may want to reconsider running only 1P in that case. If you are getting significantly more power on 2P, then you are overdriving your 1P pack. You will always get a touch more power on 2P because of less voltage drop. However, if there is a huge difference, stick with the 2P. That will keep your 1P packs from prematurely dying.
Matt
