zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.16.2007, 05:46 PM
Believe me, I have been running A123 packs since spring '06, I have had the most experience with them on this forum... a 7s1p pack can deliver 1300 watts solid, and only gets barely warm to the touch running a 1512/3D. This is probably because the truck is fairly light weight, so not much stress on the pack (plus it handles better with a 1p pack). I too usually recommend 2p packs (mostly with less than 7s though), but the combination of HV, the Neu's efficiency, and light weight truck, 1p is JUST enough to throw the truck around with authority.
As far as cycle life goes, the 1p pack is still delivering a little over 2300mah after >200 cycles at 4C average discharge (15 min runtime) and 4C/10 amp charging.
