Thread: NEW Pics!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
12.17.2007, 11:47 PM
More Jato stuff huh? Are the Jato diff output shafts 5mm? I ask because I saw this MIP Jato CVD kit. Or do you think I can use the MIP Rustler drive cups I already have? I guess the ball on the end of the CVD would need to be the same diameter. If this would all work I'll get the RPM rear arms and the stock Traxxas stub axle carriers. I like the plastic for the weight savings. If it has issues I can upgrade to aluminum later. Did you use the stock length camber links?
