crazyjr
crazyjr's Avatar
12.19.2007, 01:13 PM
only one way to find out what you like best....
Build em both and find out!
The plan is to eventually build both, I am getting out of mini's so the 1107 would be available. One will be stock with short chassis or optional ofna chassis, and the other will be a long chassis with traxxas dish wheels (not as far offset as the rustler fronts, but not as narrow as the rustler rears)
the lehner is about the diameter of a 540 motor with a slightly shorter can.
the 1107 has a long 1/8 shaft so an adapter will not be a problem, Just need an adapter because the bolt pattern is for a Mini plate
