Not shorted
ilpufxit
ilpufxit's Avatar
Not shorted - 12.21.2007, 08:58 PM
So I just brought my meter home and tested the motor. No continuity to the case on any wire. All three wires have continuity to each other. I even tried spinning the rotor with the meter on just in case.
This motor will run if you spin it up gradually but the heat build up happens too fast to even try to actually drive it.
I've heard that it can be difficult to get these fixed. Is there any (more) local alternative for repairs?
My connectors are the standard 4mm bullets compatible with MM
