aqwut
Brushless Heavy Weight....
aqwut's Avatar
12.22.2007, 01:41 AM
I honestly don't see that much of a problem either.. just ask Mike to make up a Wider Pinion or a pinion with a wider hub... I know it puts quite a bit more stress on the bearings/shaft.... but the 5mm shaft could handle quite a bit of stress as well..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
