its me
There is no help for me... I'm addicted to R/C
its me's Avatar
12.25.2007, 12:37 AM
In the above pic, what did you use as the metal shim to make up the difference in diameter between the muggy diff case and the hole in the maxx bulkhead?
Also, how did you get the retainer/locator ring to fit the nose(pinion) area of the muggy diff? The lst diff case I took a look at was larger in diameter than the inside diameter of the ring.
Drill/ dremel and PVC pipe for the spacer, try to get a tapered 1/2 PVC so when you slip them over the diff they wont pop out the bulk head.
you look right at the diff and you can see how much I drilled the yoke thingy, all of this only take about 15-20 minutes to do.
rccna.com
