12.25.2007, 12:00 PM
Originally Posted by mac View Post
lincpimp so if i want more speed and power what settup should i use and why does the velineon system have so much power and speed in the rusty and stampede the can get up around 70 with that lipo ?
Well, I would go with a mamba max speed control, castle creations bec (you have to disable the mamba max internal bec to run more than 3s lipo), a feigao 9xl motor, and a maxamps (or similar) 8000mah 4s lipo. This will be a cool running system that will have long runtimes and enough power to gear for 40mph or so and not get hot. You could also use the maxamps 4s 6000 battery, but I would say to go for the 8000 as it will offer longer runtimes and is made of better cells!
The rustler does ok with the velineon sytem due to the low weight and 2wd. The motor is really too small for a larger, heavier 4wd truck. You will notice that the mm/8xl combo will not be much more expensive than the velineon system. MM go for 135 or less and you can get the 8xl for about 60-70.
