12.26.2007, 05:10 PM
Sounds interesting.
You might want to play with the calc cause you'll find that you need quite tall gears, larger tires, higher voltage, higher kv motor, etc to reach those speeds.
Tires are gonna be tough. I don't think anything short of using foams or solid rubber will work since it will be really high to prevent ballooning.
