turbo4
turbo4's Avatar
01.01.2008, 11:16 PM
Originally Posted by mkrusedc View Post
When I repaired this I noticed that the lower spring retainer had worn a groove in my 3.3 shaft. You can see it near the lower coils of the white spring in both pics.
I'm having the same problem. I think i will go with CVD's or modify the spring perch. The perch's I have are revo ones which are more narrow, which rubs much less than the ones that came with the prolines. Mine are not grooved nearly as much as yours, but are showing signs of wear.
