01.03.2008, 12:50 PM
Originally Posted by mkrusedc View Post
Cup and bone:
3.3 shaft. The stub adapter is neede to fit the right side of the pic below:
http://www3.towerhobbies.com/cgi-bin...?&I=LXMJG8&P=7
I see your problem, you are using a hybrid bulk with a hb or similar diff that has the drive cups integrated with the output shaft. The cups that come with the cvds you are using are designed to mount up to a stock maxx diff output. They are longer than what you have now, due to the need for some method of attaching the cup to the diff output, probably a set screw. This would place the cup out another 1/4 inch or more thus taking up the slack. You would need to buy mike's diff adapter shafts and then put the cups on them to get the correct spacing. I am not 100% sure that the revo diff outputs will fit with the cups you have, never thied this, but I have to do the same on my racebomb. I have ths cvds and the ball end is too big for the hb cup, so I bought a set of mike's adapter shafts and plan to use them and the ths supplied cups, hope it works!
