01.03.2008, 09:41 PM
Originally Posted by mustbnitro View Post
Someone help me out on this one...
I am running this in a truggy on 4s with a Feigao 9XL, the only reason I was planning on doing this was to keep temps low on 15 minute mains. My whole goal with the mod was to keep temps LOW. I am going to run dual novak fans I bought as well (they look cool to which is always a plus).
Thanks!
I am guessing that you are trying to perform griffinru's stage 1 mod. If so the need for fans may not be necessary. I ran my 1/8 buggy with a feigal 7xl, geared for 40mph, and a 10000mah 4s lipo (=very heavy) with a modded mm and a regular mm. The unmodded mm did need a fan and temps were still a little on the high side. With the modded mm I did not need the fan and the overall performance was much better. Since you are running a truggy, the added tire weight will put more strain on the motor and cause more heat at the motor, that may be of more concern than the esc, however the hotter motor will cause the esc to heat up due to higher current draw for wasted power production (heat).
