sikeston34m
sikeston34m's Avatar
01.04.2008, 11:01 PM
Looks cool, wonder if those two motors are as powerful as a KB45xl on 6s? We shall see! Here is the calc with the 2 speed in 2nd gear, 1st should be good for 40 mph! I think the KB motor will pull the speed, just wonder what esc to use?
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.16
Spur Tooth Count: 48
Pinion Tooth Count: 20
Total Voltage: 22.2
Motor KV: 1700
Tire Diameter (inches): 5.75
Total Motor Speed: 37740 RPM
Vehicle Speed: 70.11 MPH
Linc!
You mean you have a KB45 up your sleeve?
